Can the CCT cause more damage?
Old 11-01-2007 | 01:08 PM
cnestea's Avatar
Default Can the CCT cause more damage?
Im bringing my bike in to see if this small noise im hearing is just me or the CCT that needs replacing but i was wondering if this is something that is safe to ride with for another month and fix in the new season? i dont want to cause any damage to the bike. It sounds like a vibration from the engine and doesnt always sound loud it may even be just the way the bikes sounds.
bike is a 2002 crb F4i with 21K on it.
Thank you,
[IMG]local://upfiles/21768/4DAFE89559CE422F8BF01BB6B88924EB.jpg[/IMG]
Old 11-01-2007 | 01:40 PM
halik008's Avatar
Default RE: Can the CCT cause more damage?
there is only slight chance that it could make the engine jump timing
Old 11-01-2007 | 02:03 PM
scattabrain's Avatar
I had my CCT replaced back in july sometime. I had the manual APE tensior put on. When it was installed the jam nut on it wasn't tightened properly and after about 1000km it backed off enough for the cam chain to jump a tooth and throw off my timing. I'm guesing you have an OEM CCT installed and therefore don't run the risk of having it back off enough to jump a tooth so I think you should be fine. If however you do have an APE CCT installed I would get it checked pronto.
Old 11-01-2007 | 03:52 PM
beef66's Avatar
Well considering that mine jumped time a would say so...
Old 11-03-2007 | 04:52 PM
atvrider07's Avatar
when your guys' jumped time, did it smash the valves or mess up the piston or anything? didnt know if these bikes have the pistons that have indentions for the valves in em so it wont hurt anything if that happens
dyracuse
01-18-2010 08:58 PM
Etalono61
10-01-2008 11:47 PM
peterk
01-21-2007 07:29 PM
javscbr
02-20-2006 03:59 PM
Bikerboy202066
07-07-2005 08:10 PM
