Cam chane tentioner
Old Aug 23, 2006 | 12:44 PM
  #21
ninetyfivehp's Avatar
Default RE: Cam chane tentioner
i wonder if all the 06's came with the 2 blue dot version?
Old Aug 23, 2006 | 12:55 PM
  #22
Tahoe SC's Avatar
i think they all did. i even made a mistake of ordering the j22 from honda direct and they still sent me the j23 cause that's all they had mang! but as far as 2 dots or 1...the last ones i ordered both had 2 dots on it...but we can't be sure...what we can be sure is that the 06s came with a spoiler on them
Old Aug 23, 2006 | 12:58 PM
  #23
i hope honda did thier homework and the j23 blue dot won't crap out as fast as the j22[&:]
Old Aug 23, 2006 | 12:59 PM
  #24
Blackdog F4i's Avatar
I have "heard" they they are no better, but only time will tell.
Old Aug 23, 2006 | 01:03 PM
  #25
ORIGINAL: Blackdog F4i
[sm=headbang.gif]
Old Aug 23, 2006 | 01:49 PM
  #26
beachaccord's Avatar
my bike has only 2900 miles on it and the sound started at about 2500 miles......it's an 06
Old Aug 23, 2006 | 04:18 PM
  #27
If you bought it new it's covered under warranty.
Old Aug 23, 2006 | 05:45 PM
  #28
rancidf4i's Avatar
I just replaced mine this past weekend with the j23 version( 2 blue dots). It had the j22 before. I noticed the major shaft play. I dont see how flaring the tip would fix the problem though. Because mine the shaft holder was actual worn down were i could jiggle the shaft around, on the new one there was no play at all just a nice solid piece. You would think that they would make the shaft holder alot shorter, or make it so you can install some O-rings or something to get rid of the play in the shaft. Well i've put at least 1k on the new j23 part and will post back the mileage when it starts to play the maracas again.
Old Aug 24, 2006 | 12:57 PM
  #29
Tahoe SC's Avatar
in my previous posts about potential sources of noise...shaft place was one of them...the majority is from the tip though...until the shaft gets worn down.
there's no cure for the shaft...see my post above and other posts...the blue arrows are the causes of the noise. i just replaced my other j23 about a month ago...no shaft play after 12K...so i'm assuming that honda did something to help rectify the situation from j22 to j23...either that or with usual wear and tear, the shaft will eventually have play in all cctl models. from my dealings with the cctl, in the majority of the cases, noise has been from the tip, which always has play, even from the factory...just a little vs. lots later...but the shaft is ok...so flaring the pin stops the noise...until the cctl body itself or shaft is so worn it starts making noise.
how many miles did you have on the j22?
f4ijrider
Aug 21, 2006 02:28 PM
dlbinford
May 11, 2005 11:30 PM
