Cam chain tensioner ??
Old Apr 9, 2006 | 08:22 PM
milko's Avatar
Default Cam chain tensioner ??
I know you been over this topic many times so bear with me. I have a 2002 F4I with 15kmiles and around 15k I here this noise...Must be the CCT that all talks about. Ok so I tyed the link on the detail pictures on how to do it but I get page cant be displayed... Has anyone ever have the dealer fix it for them and if so how much did they charge? I am by nonmeans a bike mechanie...I do diesel mechanic work for a living.
Thats for any help that you can give me
I just bought it and got a sweet deal....Dude was out of work and need cash fast
Old Apr 14, 2006 | 10:19 AM
kash's Avatar
Default RE: Cam chain tensioner ??
do you need to replace the stock CCT at all if your only street riding? Some people are saying that if you are racing on track, then you have to replace it, but if not, you don't need too. Is this correct?
2003 Honda F4i - Stock
Old Apr 14, 2006 | 12:31 PM
ryanoxj's Avatar
i just replaced mine with a stock one wasnt to bad to do, just have to be patient and work in a small place there is plenty articles on the web, step by step on how to do it. Took me about hour and a half to do it and 30 mins was trying to get the socket out of the engine area where i dropped it.
Just wondering how often do you get up to 15k, mine was making noise at about 2k to 3k.
Old Apr 14, 2006 | 12:39 PM
kash's Avatar
so you are saying to replace the stock CCT even if you don't use the bike for racing purposes?
Old Apr 14, 2006 | 01:04 PM
plasteredbassist's Avatar
check out this thread lots of great info on this https://cbrforum.com/m_85570/tm.htm
from what it seems the sound is only an annoyance no one reported any issues from not changing it like the chain skipping a tooth and destroying the engine there did however seem to be a couple ppl who put on the manual tensioner and adjusted it too tight which did mess it up. im basically choosing to live with the sound until someone can show solid proof that this will damage the engine.
Old Apr 14, 2006 | 01:06 PM
Tahoe SC's Avatar
yo mang...check it...
APE's site claims that theirs is all good and stuff for racing and what not, blah blah blah...that's all their claims or else no one is going to buy it, but yea a lot of racers do use it...
my take is this...i don't want to mess up trying to figure out exactly how much tension to use if the stocker does that for me already...
so...the stocker's known to rattle here and there, but it's by no means failing...i would rather swap it out every 10K or so...just in time to change the fuel filter...figure the tank has to come off anyway, so what better time than this?
as far as the cctl, some dealers will fix it for free. i gots mine done like after mah warranty was out...but they still fixed it cause they know it's a rattling part...after that i swapped mah own cause i like to know mah ride.
Old Apr 14, 2006 | 01:26 PM
ryanoxj's Avatar
Tahoe SC said it, why not change it i changed mine because it was annoying and sounded bad, but if it does skip timing then you are in more trouble than you want. I guess its preventive mantinence.
If you go to order one from a honda dealer make sure you order the cam chain tensioner lifter. the cam chain tensioner is what it puts pressure on that the chain runs on. i made this mistake.
Speedemon636
May 8, 2010 06:27 PM
njens118
May 4, 2010 03:44 PM
nikos
Feb 25, 2009 02:05 AM
ozrider
Feb 7, 2006 02:02 PM
radio one
Nov 8, 2005 11:38 PM
