California's most unreliable honda
Okay so I'm new to this whole forum posting stuff and I hope I post this in the correct place and my bad if I didn't. I could use some help as much as possible and I'm desperate for some help with my f4i.. for months now day after day I've been trying to get my bike to run again.. So long story short I am now at the point where I have no spark at all and yet my fuel pump still primes. I have the diode and resistor in the ignition and the tip over sensor is bypassed as well as everything else that can be bypassed
I've tried 2 different ecu computers and still no spark at all I have swapped out my cam sensors the pulse generator and stator. I have no clue what's wrong with it. My life has been miserable since my bike quit running I spend day and night trying to figure this id like to say I know alot about the 2001 f4i 600 but apparently not so what would cause it not to spark but fuel pump primes ? As far as I understood if the f4i looses spark for whatever reason the fuel pump won't prime. And if the fuel pump does prime then there should be spark. ? Am I wrong ?
I think you're wrong about the spark/pump thing. Have you checked the fi fuse? That would take out the power to the coils and injectors...
Where in California are you?
Hi , bit of a long shot here , but check the 12pin connector to the front light harness ,that holds the BAS , I know you have bypassed the BAS but if that connector is loose it will negate your bypass, grasp the connection ,hold it in tight and see if it will fire, long shot I know
The ignition has the diode, but does it drop the voltage to 9v?
