Brake Light Running Light?
Old Jun 27, 2007 | 11:34 PM
dco8415's Avatar
Default Brake Light Running Light?
This is going to sound stupid, does the f4i brake light have a running light while riding? I just installed a fender eliminiator kit and when i tap the brake light, the lights go on obviously, but just sitting there there is no light.
Did i do something wrong?
Old Jun 27, 2007 | 11:47 PM
axsys's Avatar
Default RE: Brake Light Running Light?
there should be 3 wires for each plug that plugs into the stock tail light (2 plugs for 2 bulbs). each set of wires is the same for each plug, so you dont have to worry about that. in each plug, there is a common ground, a 12v+ for the brake light, and a 12v+ for the tail/running light. i think the ground is green, the brake is black, and the running is green and brown, but im not sure about the colors. but you should have running lights and brake lights, just like every other bike.
________
Vapor info
Old Jun 28, 2007 | 09:44 AM
Candymanmo06F4I's Avatar
Yes you should have a running light
at night driving you would be a target for cagers "not seeing you" as they say.
chrislen32
Feb 6, 2011 10:18 AM
ny450
May 27, 2008 01:02 PM
ddaren
Jan 17, 2008 07:13 AM
ddaren
Jan 15, 2008 07:46 AM
