LED brake light; no running light
I have a clear alternatives LED brake light. It simply replaces the stock brake light.
Just noticed that the running brake light doesn't work. Signal lights work perfectly and when I hit the brakes, the brake lights up brightly. Just no running light.
Checked all wires, seem to be good. All connectors seem to be good too.
What could be wrong with it? Can it only be loose wires cuz I may have overlooked them. Or is it defective?
Defective or not, I got a hotbodies undertail coming in just cuz I needed to upgrade.
RE: LED brake light; no running light
You plugged both of the plugs in, right? I believe the clear alternatives has 2 plugs if I remember right. But otherwise, just gotta check and see if there's voltage getting to it. It's the blue with brown tracer, I do believe for the taillight. If it has voltage, you know the taillight is defective
2 ddaren
Do you mean this one tail light?
http://cgi.ebay.com/ebaymotors/00-03...spagenameZWDVW
I want to buy it too, so ask you to tellifyou successed in making it work as running light.
ORIGINAL: Retal
2 ddaren
2 ddaren
thirdgenlxi
tnx, your post is helpful, i suppose i'll order this one. Does it work properly as the running light? License plate light is useless because it is quite ok to ride without registration number.
ORIGINAL: Retal
thirdgenlxi
thirdgenlxi
Okay guys, figured out my problem. There are normally 2 plastic connectors that have 3 wires going into each of them. I believe the 3 wires is ground, running light, and brake light.
Since the Clear alternatives LED brake light only requires one of these 2 connectors to be used the other can be left out. However, the one that was connected was broken in a way. There are 3 metal prongs on the plastic connector that connects with the tail light, I noticed one prong was completely broken. That one was the running light. I simply used the other connector and worked perfectly!
attached is a picture with the 2 connectors circled.
my FI light is on and there is a red light i think its the mil light and bike is running great HELP!
cubanjoe
12-27-2007 09:00 AM
