Brake lever pushing on button
Old Apr 9, 2025 | 11:25 AM
Allenwyatt600f4i's Avatar
Default Brake lever pushing on button
Hey guys new rider so i don’t know all the terminology but basically i bought a 2004 cbr 600f4i and the brake lever seems to be pushing on the button (not sure what it’s called) that activates the brake lights. Currently the lever is constantly pushing on it causing the lights to stay on. Is there a spring inside the mechanism i can replace or do i just need a whole new one? It does have aftermarket levers that are adjustable. I also thought that i might need a new cable since maybe it has stretched and isn’t keeping the lever tight. Any help or thoughts would be appreciated
Old Apr 10, 2025 | 11:42 AM
NeoClone's Avatar
That button that the lever is pushing on is your front brake light switch and that is normal. You probably have bad switch. It is what is called a 'normally closed' switch which opens the circuit when it is activated. It is relatively easy to replace and you can find it on eBay or Amazon.
as far as the brake cable being stretched, it is adjustable, but it might be that the lever may be worn where it the cable end anchors on it. Check for play there and if you have to replace that as well. Those are easy to find on eBay or Amazon as well. I recommend the 'roll-a-click' type cause those you can adjust to preference even while riding. Hope any of that helps. Safe riding and keep the rubbers down!
Old Apr 10, 2025 | 04:07 PM
Scott91370's Avatar
There are no brake cables on the F4i - they are both hydraulic.
You should be able to hear a slight click when you pull the handle in. This is the switch. You could also take out the screw in the middle of the handle mount which will remove the handle. If the light stays on you'll know it's the switch not returning to the off position.
I would also check the switch on the rear before replacing anything - it could be that one
Stegedman
Jan 19, 2021 02:01 PM
flipper1939
May 9, 2011 02:51 AM
adamw89_2000
Jul 23, 2010 01:29 PM
Destinmatt
Jan 4, 2006 09:46 AM
