brake calipers question
Old Jun 12, 2006 | 04:37 PM
spidertron's Avatar
Default brake calipers question
well today i was checking the brake calipers. Is it normal that one of my piston moves out further than the other?? and another thing is i screwed up by applying brake too much to check and one of my piston poped out i heard that usually u replace your piston seal when u rebuild caliper or when you remove the seal for any reason. Since my piston poped out is it alright to just.... push it back in? or i should just dissasemble it and rebuild it and get a new piston seal...
thanks
Old Jun 13, 2006 | 02:21 PM
Jaybird180's Avatar
Default RE: brake calipers question
Wish I had the expertise to answer.
Don't mess w. brakes if you don't either
:Bump:
Old Jun 13, 2006 | 07:39 PM
Tahoe SC's Avatar
it popped out mang?
just rebuild it...lots of little seals, etc...i rebuilt mine like 6 months ago...works great...
pistons stick when there's gunk built up around it...that's why you should bleed every six months or yearly depending on how much you ride.
you have air in the system now, at the very least you'll need to rebleed the brakes to get the air out.
if you don't get new seals, keep an eye on that piston for weaping brake fluid. if it doesn't leak with lots of brake pressure, you should be ok.
Migge
F2 For Sale / Trade / Wanted
Jan 29, 2014 04:52 PM
hurricane88
May 31, 2009 11:33 PM
BigCat
Mar 26, 2009 08:54 PM
rodantking
Oct 31, 2007 10:08 PM
SkinnyJ
Mar 19, 2007 07:18 PM
