Bought new Frame Sliders
Old Jan 7, 2006 | 04:27 AM
pupdog_88's Avatar
Default RE: Bought new Frame Sliders
just take the fairing off and take out the bolt that slider goes in put the new longer bolt in the hole about 2-3 threads put the fairing back on and just press against where the bolt is it will leave a mark on the inside of the fairing take a drill and drill right in the middle of the mark than put on a hole saw that just clears the slider and drill right threw it from the out side of the fairing and you have one straight hole that is the right size, did mine and they came out perfect.
Old Jan 7, 2006 | 04:35 AM
NINE2NINE's Avatar
Retired Mod
ORIGINAL: brancart1
i dont understand how you could use a laser pointer? anyone got the write up for the laser pointer?
here is a link for different ways for installing frame sliders, including the laser pointer method. hope this helps.
Old Jan 7, 2006 | 04:44 AM
pupdog_88's Avatar
i've never heard of the laser poiter method but that is a sweet *** idea i'll try that next time i put on a set of cut-out frame sliders.
Old Jan 7, 2006 | 02:54 PM
pitsvtec's Avatar
I bought Lightening so I wouldn't have to drill into the fairings. But post pics when you get them done.
Old Jan 7, 2006 | 03:05 PM
doncollins's Avatar
Retired Administrator
The laser method is easy... just remove the plastics and prop up a laser level, not just a pointer, on the head of the engine mount bolt. Make sure the laser is level with the bike. Now that you have the red dot on the bolt, put your plastic back on and mark the red dot. Important part. Take the plastic back off and make sure the dot is still in the right place. If it is, you just verified that the hole will be right. Like I said before, measure your sliders/pucks... I read 2" every where and never thought to check. With my Vortex sliders, 1 3/4" would have fit better. PM or ask if you have any more questions... this is an easy mod to do but you don't get any second chances on it.
daveray
Oct 4, 2010 05:03 PM
Security Monster
Jul 10, 2010 12:59 AM
captain crash
May 17, 2010 06:30 PM
MisterBasket
May 31, 2006 07:51 AM
