boots drag
Old Aug 30, 2006 | 04:03 PM
  #51
Tahoe SC's Avatar
Default RE: boots drag
ask mugochap, he was hanus enough to run stock can and rearsets at the track...but i believe his issue was grinding down the stock pegs not the can...
you can get a semi view of what would hit first, but just remember, when you're in a corner, the suspension is compressed...so you have even less lean before you hit stuff...
woodcrafts aren't adjustable...they go like 1" back and 1" up or something like that...but if you want gp shift...just switch out your lever for a blackbird or VFR one...and since jaymang as size 12 feet, shouldn't be a problem reaching it...
otherwise, cut the sprocket cover.
Old Aug 30, 2006 | 04:10 PM
  #52
ninetyfivehp's Avatar
aftermarket can
Old Aug 30, 2006 | 04:36 PM
  #53
Jaybird180's Avatar
ORIGINAL: Tahoe SC
Dayum, I've visited this topic like a gazillion times before, and the same answer seems to keep coming up. I want to be able to play with the settings to find what is comfortable for me. Heck it just may be the standard 1" and 1" or something else. But oooh wheee, rearsets are sexy as hell. Plus the added crash protection I need. VFR/BBird parts cost money, but cutting the sproket cover....I'm sure Honda put that thing there for some purpose...I mean it's not like an appendix or that dangly thing in the back of your throat.
PPL: take off your feelers. You'll feel much better about yourself. Besides they're only there for insurance reasons.
Old Aug 30, 2006 | 05:07 PM
  #54
Spike's Avatar
Yeah take the peg feelers off... but keep in mind that even with them off you can still scrape the hell out of the stock peg!
I did this at the track this weekend, almost made me wreck!
Old Aug 30, 2006 | 05:18 PM
  #55
Blackdog F4i's Avatar
yep, the bottom of my stock pegs are a little "crunchy".
Old Aug 30, 2006 | 05:29 PM
  #56
thats freakin scary, looks like rearsets are your only choice then[sm=headbang.gif]
Old Aug 30, 2006 | 06:01 PM
  #57
Jaybird180's Avatar
Interesting. I didn't scrape pegs but my tire wear is nearly to the edge. Maybe you're bottoming your suspension.
Old Aug 30, 2006 | 06:16 PM
  #58
Spike's Avatar
Oh, mine aren't almost to the edge!!
Old Aug 30, 2006 | 06:23 PM
  #59
Jaybird180's Avatar
OK, you got me by a couple of milimeters. But still check your suspension. The falling feeling you could have had may have been too much lean angle. Try adjusting your pressure. 2-3 psi lower should help.
Old Aug 30, 2006 | 06:44 PM
  #60
Spike's Avatar
Yeah the suspension is stock AFAIK, and I was running 36/36 I believe on the track. I didn't check actually haha I just went out there and ran. Don't you want stiffer suspension for the track so you don't have as much compression while leaned over, hence giving you more lean angle?
