Bike won’t run in gear
Old Apr 17, 2022 | 08:46 AM
danluke1640's Avatar
Default Bike won’t run in gear
Hi
i have a cbr600 f sport / f4i
i got it running after sitting for a couple of years and now when I put it into 1st gear with the kickstand up the bike stalls straight away. I have checked the side stand switch which is working fine and I have also checked the clutch switch which is also working fine. Is there anything else that I need to check or is there anything else that might cause the issue. Maybe a wiring fault somewhere? But not sure where to start with that
cheers for any help
Dan
Old Apr 17, 2022 | 09:11 AM
Hey there. I would check the kickstand switch. It may be failing. It's a fairly easy thing to do. Basically you are applying a jumper wire to the contact points forcing it to act in the "up position".
Old Apr 17, 2022 | 09:25 AM
Hi
i have already tested the side stand switch and cleaned it up. It works fine. So not sure what else to check
cheers
Old Apr 17, 2022 | 09:45 AM
cbrbike's Avatar
hi. did you check side stand switch with a multimeter ? if it's ok i would check continuity of Green/White wire between side stand switch and the ECU socket
Old Apr 17, 2022 | 10:14 AM
Hi
yes i checked with my multimeter on continuity . I will try to trace the cable later today and see if any of the wires are damaged. I did link the terminals in the green plug but the engine still stalled when I put the bike into gear.
cheers
Old Apr 17, 2022 | 11:19 AM
Just tested the green plug from the bike side and I am getting 5v between the pins , not sure if that’s correct or it should be 12v ? Hopefully that might narrow the problem down
cheers
Old Apr 17, 2022 | 11:25 AM
Originally Posted by cbrbike
hi. did you check side stand switch with a multimeter ? if it's ok i would check continuity of Green/White wire between side stand switch and the ECM socket
The Side Stand Switch is providing a ground path on Pin 21 (the Green/White wire). With the Side Stand in the up position you should have continuity from that Green/White wire to frame ground, or the Neg terminal of the battery.
Update
So, I was doing a check on my ECM for another person with a suspected bad one. I went ahead and checked from the Green/White wire to the frame and with the Side Stand in the up position, it had 0.0 Ohms (good continuity). With it down, it read about 1.8 K Ohms.
Old Apr 17, 2022 | 01:07 PM
cbrbike's Avatar
hi. could you check for this continuity (ohms reading) .
A - Green/White wire at ECU socket
B - Green/White wire at side stand switch ( bike side )
Old Apr 17, 2022 | 01:19 PM
Excellent thank you I will check the wiring in the morning
dan
Old Apr 18, 2022 | 05:01 AM
Hi just a quick update.
i tested the green to earth - all good
I tested the green/white to pin 21 ecu - all good
bike still cut out as soon as I put into 1st gear
started bike in 3rd gear and it stayed running so went down to 1st gear and it stayed running.
i then turned the bike off and restarted it in 1st gear and it ran perfectly
so not excactly sure what I did or it needed to be started in 3rd gear first but it’s running perfectly now
thanks for all the help
Dan
