Bike is all jacked up
RE: Bike is all jacked up
I had a similar problem (not with my F4i) with my car. It would shake and seem to jump around at low RPMs when I accelerated from a stop. I had just changed the plugs & leeds when it started and it turned out that a few of the new plugs were bad and that was what was causeing the problems. Try checking to see if any of the leeds or plugs are bad it may solve your problems. You could also have filled up with some crap gas which has fouled you plugs, try running some premium fuel from a different service station throu the fuel system. Hope this info helps.
One way to clean plugs etc is to run Seafoam through the fuel... which will also stabilise your fuel... very useful (from my experience and many threads on this forum)
Plugs need no changing even at the 12k service, unless bad gas etc has caused problems.
Battery could be one issue, a bad fuel pressure regulator could be another...
ORIGINAL: BigTX
Got into the bike alittle bit today and unplugged the pc and messed with the battery and replugged the power commander and now she is purring again. I think it was just a battery terminal loose. Thanks alot guys!!!
