Best 2004-1006 undertails
Old 02-16-2007, 10:35 PM
CBR BoyRacer's Avatar
Default Best 2004-1006 undertails
I know this board seems partial to rumble undertails for the 04-06's. I am definitely getting an undertail but I'm debating between the rumble, mototeck, and devil. Rumble seems to be the least expensive, but is there any other advantage? I am curious as to which one has the best and brightest LEDs.
Old 02-17-2007, 03:33 AM
Default RE: Best 2004-1006 undertails
From what ive read that the Brake lights are fine but th turn signal LED's are kinda dim..but that shouldnt be a hard fix...
Old 02-17-2007, 04:15 AM
ddaren's Avatar
2004-1006 undertails... watch out... it's the 1006 undertail.
Old 02-17-2007, 04:26 AM
Mad's Avatar
Mad
Mad is offline
I've got the Rumble. Tail lights are bright but the turn signals are not that great. Need to be mod'd. I can't speak for the rest.
Old 02-18-2007, 12:14 AM
Thanks for pointing out the 1006 typo...
Question about the rumble: If you are turning will the right or left tailight blink with the right or left turn signal? Or is that a separate kit?
Old 02-18-2007, 12:38 AM
Mad's Avatar
Mad
Mad is offline
I am assuming you mean "Will they blink together with the front turn signals" . Is that right?
I have rumble flush mounts as well. They blink at the same rate (together) as the front. Even the indicators blink at the same rate. Works just like stock but just a little faster; which I like. Again, I didn’t use resistors.
Old 02-18-2007, 01:17 AM
I have the mototeck on my 04 and the turn signals are not bright enough to be seen during the day. At night they are perfectly fine. The fit of the undertail is nice, and it looks like a factory piece.
Rob
Old 02-18-2007, 04:48 AM
Default RE: Best 2004-2006 undertails
Sorry if my questions was confusing. I wasn't talking about the front turn signals. I know that there are two taillights and two turn signals on the rumble undertail. I was wondering if the right tailight would blink with the right rear turn signal and vice versa since you can't see the signals. If not I'm sure there's a kit I can buy to make it do that.
Old 02-18-2007, 07:07 AM
Mad's Avatar
Mad
Mad is offline
Oh yea that's a cool idea. What do you think of THIS?
Old 02-18-2007, 04:23 PM
I like that. It makes you a lot more visible, especially if your signals aren't that bright.
Rumblebug77
01-14-2008 04:47 PM
JDubF4i520
12-07-2007 08:58 AM
SpeedingF4i
02-17-2007 03:12 PM
snobrdrdan
04-08-2006 06:22 AM
mustang
09-05-2005 05:18 PM
Quick Reply: Best 2004-1006 undertails
