Best 2004-1006 undertails
I know this board seems partial to rumble undertails for the 04-06's. I am definitely getting an undertail but I'm debating between the rumble, mototeck, and devil. Rumble seems to be the least expensive, but is there any other advantage? I am curious as to which one has the best and brightest LEDs.
RE: Best 2004-1006 undertails
I am assuming you mean "Will they blink together with the front turn signals" . Is that right?
I have rumble flush mounts as well. They blink at the same rate (together) as the front. Even the indicators blink at the same rate. Works just like stock but just a little faster; which I like. Again, I didn’t use resistors.
RE: Best 2004-2006 undertails
Sorry if my questions was confusing. I wasn't talking about the front turn signals. I know that there are two taillights and two turn signals on the rumble undertail. I was wondering if the right tailight would blink with the right rear turn signal and vice versa since you can't see the signals. If not I'm sure there's a kit I can buy to make it do that.
