bent clipon
Old Jan 28, 2008 | 09:51 AM
Ace_f4i's Avatar
Default bent clipon
this sounds pretty noobly, is my left clipon bent? it sure as hell doesn't LOOK like it's bent but my knuckles touch the air duct covers. just wondering if i am going to need to get new ones before i take it to get inspected.
Old Jan 28, 2008 | 11:10 AM
Ruftags's Avatar
Default RE: bent clipon
It probably isn't bent unless it went down pretty hard on that side. You can loosen them up and move it out for more room. It isn't hard at all. I did it on my left side , but that was after a lowside that had moved it a little. No biggie at all.
Old Jan 28, 2008 | 11:29 AM
Tahoe SC's Avatar
stock clip ons have this little tab on it...did yours break off? if you break it off you can get more room to rotate, otherwise, you have mm's to work with.
Old Jan 28, 2008 | 11:33 AM
Ace_f4i's Avatar
i took the entire front end apart last summer to change the fork seals. i'm not 100% sure but i think i had it turned so it wasas far forward as it would go. it's frustrating and not safe so i want to fix this before it gets warm out. there is literally no room for my hand with the bars turned to the left lock.
is there any way to adjust the height of the bars? i need a half an inch at least.
Old Jan 28, 2008 | 11:35 AM
Ace_f4i's Avatar
the bike has been down before but there isn't any abrasion marks noticable on the clip-on so id on't knwo if it hit there. i bought it really cheap off a scrub that had it down and got scared to ride again.
Old Jan 28, 2008 | 01:04 PM
Jaybird180's Avatar
It takes about 5 minutes to remove the bolts for the clip on and upper triple. Once you re-seat and get the same results, then something is misaligned. Sometimes it's tough to hunt them down.
Old Jan 28, 2008 | 02:52 PM
Tahoe SC's Avatar
post a pix of your set up if you can...it may, would, could help!
Mattson
Jul 6, 2013 03:05 PM
yteka99
F3 Wanted
Jun 25, 2012 08:27 PM
Ace_f4i
Apr 7, 2008 07:46 PM
TK954RR
Apr 4, 2008 09:07 PM
klutch_r
Nov 6, 2007 09:11 PM
