Battery Died
Old Jun 9, 2007 | 01:13 AM
VoodooStar's Avatar
Default Battery Died
Yesterday on the way back from work I stop to gas her up & the bike refused to start. The battery was dead. Jump started her & all was fine. Now before the battery died I was stuck in traffic for about 20 min with my highs on at around 10-20 mph. Could this have caused it ?
Have to ask, can being in the sun all day long cause the battery to die, somebody told me ??
The battery had died once before in Jan 07 & it was cause it was sitting for about a month. Got her recharged from the dealer, never had a problem since.
My bike's a 06 with about 7000 miles on her, is it time to replace the battery already.
Thanks
Ashish H.
Old Jun 9, 2007 | 01:31 AM
01600F4i's Avatar
Default RE: Battery Died
time to replace? Not a chance. Hot weather, being in traffic, using high beams, etc... will wear the battery down quickly. Once you've idled for so long in traffic with hi beams, once that fan kicks on and is running, the odds of your battery dying are good. Don't run with the high beams on during the day when traffic is thick. Happened to me a lot. I stalled out in a traffic jam once.
Heres what you do in a jam though...
Put the bike in first gear, stand next to it, put up the kickstand, hold in the clutch, have the key turned to "On" and have the fuel pump on.
Run as fast as you can with the bike, try to get it up to 10 MPH or so, hop on the bike and pop the clutch. She'll start up. Sometimes a jump isn't always around. I've done this a few times.
Old Jun 9, 2007 | 02:05 AM
VoodooStar's Avatar
Damn, I didn't think about that fan. I'll check her tomorrow.
How much should a compatible battery cost & at what rpm does the battery actually start to get charged while running. I know it doesn't happen at lower rpms.
Thanks
Old Jun 9, 2007 | 02:30 AM
mephy04's Avatar
I just bought an Xtreme battery for 65$ plus 10 shipping. Got here in 2 days.
Old Jun 9, 2007 | 04:37 AM
F4iT's Avatar
if you tryit in 2 gear its a little better because its a higer gear just pull the clutch in as soon as it starts had loads of exp in the woods with my dirtbike
Old Jun 9, 2007 | 01:02 PM
areacode312's Avatar
Is there a Batteries Plus around you? Check out their website.
That or Wal-Mart.
Old Jun 10, 2007 | 04:43 AM
VoodooStar's Avatar
It seems like the battery should be fine. I went to check on her last nite & she started rite up. Drove a lot today. Maybe I'll get the battery tested at out local shop before I get a new one.
Old Jun 10, 2007 | 04:48 PM
IDL's Avatar
IDL
Yeah I had battery problems a while ago and it turned out to be the regulater. If you don't have any more problems then dont bother getting a new battery. Mine got to the point where it was dying often so I had to get it looked at, but I wouldn't bother if it's a one off thing.
I had to jump it constantly and I found being in second gear was easiest. Also I'm tall enough to get the bike going fast enough while sitting on it. I can't believe how easy these things are to jump!
Old Jun 10, 2007 | 07:59 PM
fishfryer527's Avatar
My 06 killed the battery at EXACTLY 7005 miles. The bike died after 30 minutes of 50mph. low beam only, push started (2nd gear..hill helped) and took it home to charge. It didn't take acharge.
I bought a newbattery 800 miles ago and haven't had a problem since.
Michaud85
Aug 17, 2012 12:57 PM
v4id
Sep 3, 2008 11:31 AM
KoukiFC3S
May 10, 2008 09:45 AM
terrible one
Jul 15, 2007 10:34 PM
