Battery charging issue
Old May 12, 2013 | 12:15 AM
Fenil's Avatar
New Member
Default Battery charging issue
Hi,
I am using an Honda CBR F4i (2004). Since last few day I am having the problem of battery charging.
I checked the alternator output and it gave me 38 volts AC @ 5000 rpm, but as per the forums this value should be around 50 volts AC. So I changed the stator but there we no changes in the readings ( it gave 38 volts AC @ 5000rpm). Then as stated in the engine service manual, I checked the stator and got the following results:
1. The resistance between the three yellow wires of the alternator were 0.6 ohms (should be between 0.1 ohms to 1 ohms as stated in the service manual).
2. There was no connectivity between the yellow wire and the ground
This led me to conclude that the stator seems to be working fine.
I also tried changing the batteries but the result was the same. The engine would fire up and will run, but the battery voltage never went above 12.5 volts as measured at the battery terminals and would start droping.
Then I went on to the rectifier/regulator. I checked the output at the rectifier and it gave me an value of 15 volts DC (which it should be giving). I also tried changing the rectifier but still the battery charging issue prevailed.
So can anyone help what could be the issue and what else to check? Could there be a problem with the flywheel? Also could a patch of rust on the flywheel cause this problem?
Thanks in advance.
Old May 12, 2013 | 04:26 AM
"A"'s Avatar
"A"
Check the battery voltage at 5000 rpm, should be 14.4 V.
Old May 12, 2013 | 04:27 AM
svek's Avatar
Possible bad connection on one of your leads.
Follow this flowchart from the start: http://www.electrosport.com/technica...ng-diagram.pdf
Old May 12, 2013 | 08:24 AM
Fenil's Avatar
New Member
As I said in my previous post the battery voltage never went above 12.5 volts after firing the engine. This even happened when a put a fully charged battery. At start voltage is around 12.8-12.9 volts and then it starts dropping and never goes above 12.5 volts.
Old May 16, 2013 | 08:27 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Did it point to anything specific when you followed that charging system troubleshooting flowchart that someone posted a link to earlier?
kaymoto
May 2, 2012 08:10 AM
b600f4
May 14, 2010 11:47 PM
njdjh2o
Apr 11, 2008 07:20 PM
marc0011
Sep 27, 2006 07:18 AM
maxima/nismo
Aug 18, 2005 05:41 PM
