Battery Charging Amps?
You should look into the 'maintainer' types. They will cycle off, cycle on, and do another electrical trick to keep the battery healthy. I believe a 2 amp steady without cycling off will be somewhat harmful. I would also remove the bike's cables from the battery.
http://www.motorcyclebatteriesusa.co...asp?battery=91 this would do the trick!
2 amp charger is insufficient info... battery maintainers have specific charging profiles so that the battery stays fresh. constant 2 amps charging will certainly destroy the battery (and possibly stuff around it!). I suppose you mean a lead-acid charger with 2A capacity??? I'd say best to get one of the chargers meant for bike...
