Bad hesitation under 3k rpm, then takes off... need help!
Old Jun 10, 2022 | 04:36 PM
Philly_Oskar's Avatar
Default Bad hesitation under 3k rpm, then takes off... need help!
I just bought an 02 f4i. It's clean, with 20k miles. It ran great when I bought it. After a day or 2, it started having a misfire and I could smell the fuel rich exhaust. I will mention there are no f1 lights. I pulled the air filter and it was the worst air filter I ever saw. I replaced it with a new k&n. It ran slightly better. I ordered new plugs. When I pulled the old plugs, they were all pretty black, and the one was clearly fouled. It was wet, and you could smell the fuel. I put new plugs in and it ran so much better, but it still hesitates when I first take off to a point where its sputtering no matter how much throttle I give it, until around 2500-3k rpm then it clears up and takes off. Then when I'm cruising at like 5500-6k rpm holding a steady throttle, you can hear the exhaust sputtering Instead of that crisp smooth sound. I just bought a new fuel filter, waiting on that to come but I'm lost on what else it could be. I was thinking maybe FPR but dont want to spend $70 on a OE Honda fpr for it not to work. I don't want to keep throwing parts at it aimlessly. Any ideas on what troubleshooting I could do to try and figure out the issue so I can fix it without throwing tons of money at it would be greatly appreciated. Thanks in advance!
Old Jun 11, 2022 | 08:22 PM
"A"'s Avatar
"A"
Is there fresh fuel in the tank? any rust inside the tank?
Old Jun 13, 2022 | 08:30 AM
Fresh fuel, no rust. The guy before me ran some fuel injector cleaner through so maybe something dislodged and clogged up an injector but I would think it would steadily run messed up. I heard before after a bike is dropped on its side, sometimes the fuel filter acts up so I'm hoping when I put the new fuel filter on it helps. I'll be doing that in the next day or so. I don't know how to check Injectors or I would pull them and check them. It really sucks though bc starting out at lights, the bike just sputters then takes off and it sucks when I'm turning at a light. It's borderline unsafe.
Old Jun 22, 2022 | 10:16 AM
JakeMN's Avatar
Could it be something to do with the clutch? My bike also does this once in a while if I let it out too quickly it sputters and the bike shakes and doesn't get power until 4-5k. I know how to use the clutch obviously but lets say I'm attempting to race someone, there's no way I can start from a stop. Tried going against a tesla and he got about 100 feet infront of me before the bike even started making power lol.
I am curious to see what you find out!
Cbgsandy
Jul 31, 2011 04:02 AM
chris45601
Jun 21, 2010 12:13 AM
shanecbr600f4i
Dec 7, 2009 11:36 PM
Grumpy92
Oct 18, 2008 02:06 PM
rtd2005
Apr 26, 2007 10:18 PM
