Bad gas mileage...
Old Aug 3, 2012 | 09:56 AM
pookguy88's Avatar
Default Bad gas mileage...
I know there a ton of gas mileage posts but hear me out..
so I'm getting about 108miles before the reserve light comes on, when the light comes on I fill about 3.2gal... so that works out to about 33.75 mpg.
everything seems to be running fine so I'm not sure what the issue is, I don't drive like a maniac and shift at around 5-6k rpm...
anyone have any suggestions? thanks!
Old Aug 3, 2012 | 10:19 AM
boredandstroked's Avatar
Change your plugs, air filter, and oil, clean and lube your chain and use stock gearing. If that doesn't work check your compression.
Old Aug 3, 2012 | 10:21 AM
svek's Avatar
I've gotten mileage that low. I've also run 160 miles on a tank. Check your tire pressure, stay tucked under the windscreen, and don't be afraid to rev it more than 6k. Do you ride in the city a lot?
Old Aug 3, 2012 | 10:32 AM
pookguy88's Avatar
I ride almost exclusively in the city, almost no highway at all, 80% of the time I'm under 60mph
good call with the tire pressure, I think my rear tire might need some air
I've done all that except the plugs, maybe I'll try that next; do you think they could make a big difference mileage wise?
Old Aug 3, 2012 | 02:21 PM
svek's Avatar
Yep, bump your tire psi to the max listed on the frame, I think its 38f and 42rear.
Old Aug 3, 2012 | 04:32 PM
omg209's Avatar
you call that bad gas mileage???? i get 32mpg and i shift at 4k! with a -1 front
Old Aug 3, 2012 | 05:01 PM
Trent Dog's Avatar
Registered Users
I get 160 a tank, and I live in the mountains! Twisty riding almost every day for me!
Old Aug 3, 2012 | 10:14 PM
Yes, especially combined with lower tire pressures. Anything over 14k on my plugs and I can feel the difference in engine operation, don't even need gas mileage to confirm they're getting dirty.
LuckyHooligan
Jul 2, 2008 08:22 PM
boosted_f20c
Feb 13, 2008 02:43 AM
mattthecat
Feb 12, 2008 12:56 AM
JR Leonard
Nov 17, 2007 11:31 AM
kennys223
Sep 14, 2007 02:43 AM
