Axle spool holes
Old Apr 1, 2007 | 07:37 PM
ZoomByMe75's Avatar
Default Axle spool holes
Are there holes on the f4i for the spools for rear stands, or do you have to drill them?
any suggestions on stands and spools??
Old Apr 1, 2007 | 09:14 PM
woodyracing's Avatar
Default RE: Axle spool holes
no the F4i doesn't have a way to mount spools as stock, you have two options:
1. buy weld-on tabs from Pit-Bull, weld them to the bottom of the swingarm
2. buy the LP spool insert kit, drill a hole in the swingarm and pop in the inserts
imo Pro-Tek makes the best spools/swingarm sliders, especially for the F4i they have a "lip" that sits against the swingarm as its bolted in that will give it a little more support if you happen to crash so it doesn't just break the tabs off (hasn't been an issue for me anyway with 3 crashes but just in case)
brad21803
Aug 19, 2011 11:14 AM
jetjestor
Jul 9, 2008 12:06 PM
zerog_85
Sep 19, 2006 10:13 PM
city worker
Aug 5, 2006 02:58 PM
