asking for tips
Old May 14, 2008 | 02:35 PM
CBR Time's Avatar
Default RE: asking for tips
ORIGINAL: MC_spirited
The MSF is good, but some things I dont agree with. Specifically their advice to NOT cover the brake and clutch. I always cover the brake and clutch with two fingers when my hand is on the bar. Sometimes I let my clutch hand rest, which is not very safe in some circumstances. Remember that the rider makes the bike, not the other way around. That being said you must make sure your machine is safe, check at the very least your tires before you ride. If you are going to be getting spirited, make sure you check them as tire pressures affect your cornering significantly. For longer tire life/highway riding run more pressure like 34/38 or something to that affect. I usually run about 32/35ish. Check tire pressures cold and remember that they will increase pressure because of the heating of the tires and air. Make sure not to neglect your chain, clean, lubeand inspect it at the very least every 500 miles, more like 200-300 miles. If you want to increase the performance of your bike, spend the money on a trackday instead. 95 percent of riders do not or cannot ride their bike to the edge of its cornering and accellerating abilities. The price of one speeding ticket could pay for an entire trackday, and it is safer and much more fun than the street. Some track experianced riders do not even ride on the street. Im sure their has to be one person that feels that way here. Trust your tires, I doubt you will ever lean over far enough to not be able to throw it over more if need be. Always ride like there is going to be a refrigerator around every blind corner you approach. If you get into trouble in a turn (too fast, bad line) do not brake. Most times the bike can be leaned over more, If you cannot trust your tires, get new ones. If you get into trouble with the rear end sliding on you because of too much accelleration, closing the throttle is the wrong answer. Ive never been in that situation, but racers have a saying, "When in doubt, Gas it out". Closing the throttle would lead to you getting thrown over the top of the bike as the rear tire violently regains traction.
Go to a parking lot and practice braking manuvers. Set up a turn and practice going through the turn and at the midpoint of the turn, stand up the bike and brake. Accellerate straight to 25mph then brake. Get your distance down as much as you can. When you feel comfortable, bring it up 5mph at a time. Everyone who rides should practice emergency braking at all speeds, but it is hard to find a spot to accellerate to 50-70 mph then brake hard safely. Go slow with it, Be smooth, progressive and deliberate with all control inputs.
When cornering dont be afraid to get your *** off the seat. Hang off half your *** in the direction you are leaning. This eliminates leaning the opposite way you turn. It also gives you more proper posture. Remember to keep arms and hands relaxed and most of your weight on the pegs. In a bumpy enviroment or while turning, you should be like a jockey with most weight on the feet. While cornering keep some on the seat, but for bumps and obsticles get all the way off.
Besides winding it out through a tunnel or bridge overpass, and riding the twisties, the thing that makes me smile the most is when there are cars approaching a train crossing and they are slowing down as I pass them on the tracks. ****ing vaginas.
Well said[sm=smiley20.gif]
Old May 14, 2008 | 04:00 PM
MC_spirited's Avatar
Its one thing knowing the right way to ride, but it takes much concentration to actually apply everything that you should while riding. Riding is very draining on the body and mind. Add in engine and wind noise, hot temperatures, dehydration and other factors it can get dangerous. Sometimes it feels better to be home safe and relaxing than it does to actually ride. Hope these tips help out some people, there are many more to know.
smoorebmw
Aug 24, 2011 09:16 PM
Jesse2008
Sep 11, 2008 10:26 AM
RooR Mast3r904
Apr 13, 2008 08:40 PM
95HondaCBRF3
Nov 6, 2007 08:32 AM
JRdaHNIC
Mar 30, 2006 10:15 AM
