Ahhhh!! This is frustrating!!! Help plz!
man.. this sucks. to be short.. my headlights dont work. when i got back from riding i turned the bike off and tried to turn it back on to move it and it wouldnt prime. so i wiggled the plug that goes to the headlights wiring harness and it came on. so i move it in the garage and turn it off and try to turn it back on, the fuel pump primes and the bike starts, but the headlights dont work. i just replaced the bulbs and stuff so im confused. could i need a new wiring harness? whats the deal? I NEED THIS SOLVED NOW HA HA. SUNS FINALLY OUT SO I NEED TO GET THIS TAKEN CARE OF, OR IM GOING TO GO RIDE WITH NO HEADLIGHTS LOL
thanks again cbrforum
um at one point while i was toying around the blue light for the hi beams stayed on but i adjusted the wires a little bit and everything went back to normal, just the headlights dont come on. but i looked in the fuse box and it looks like i blew a fuse so im going to replace it and see how it goes. thanks alot for your help though.. i hope i dont need a new harness, i cant afford it right now after buying an entire fairing kit
Ah definitely wanna check out that fuse, good call on that. Other than a fuse, not sure what it would be besides a new harness, would say a connection or something, but your bike fires up fine so you know that the BAS is getting through. But yeah I hear ya, the fairing kits really put you out...
hey mav, thanks alot man. yea it was the fuse for the headlight. i wouldnt have thought to check them either, but i was doing a search on the forum to see if anyone else had the same problem and saw some stuff about blowing fuses.
but yea i appreciate you responding
just a thought make sure your headlight plug in is connected all the way i know from cars if the fuse is old and weak and the connection is is moved enough it can spark just enough to blow a fuse.. just my 2 cents...had same problem on my 82 chevy truck..
Sparks don't blow fuses. High current flow (short to ground ect) does
ha ha sorry jp i keep forgetting.
but yea i spoke too soon.... i replaced the fuse but for some reason when i jiggle the plug where the harness connects to the bike it cuts off and has the blue hi-beam light on.. could it be the harness or the bike? AHH!!
