adding led's for running/brake light
Old May 25, 2008 | 10:05 AM
Aken's Avatar
July 2008 ROTM
Default RE: adding led's for running/brake light
Yup yup.
Old May 25, 2008 | 10:27 AM
ny450's Avatar
thanks man, you and axsys are a huge help...ill be sure to post up some pics once the led's come and i get to work
Old May 25, 2008 | 11:21 AM
axsys's Avatar
no problem. well be waiting for pictures!
Old May 26, 2008 | 08:43 PM
BRRandon's Avatar
J&P Cycle(www.jpcycles.com) sells a wiring harness/plug that allows you to use and LED(or LEDs) as running and brake/turn signal lights. if anyone wanted to know. i ran into it on accident. lol.
Old May 27, 2008 | 11:20 AM
MidnightG35X's Avatar
ORIGINAL: ny450
ok so far this is what i got for one peg...i will be using the oznium 3mm's(pre wired w/ indiv. resistors)
good? no good?
So am I looking at this correct? Are you running just 1 LED with a resistor to the battery? If so, that is a pretty big waste in my opinion. This is especially true if you are using an LED with a drop of about 3V and lets say 20mA. Assuming a 14V system (as per reasons mentioned above already) that means each resistor is 550 Ohm and the power dissipated by each resistor is going to be 220mW. If you really want me to go through all the math, I will. A lot of resistors out there are only 250mW resistors, and this is going to mean the resistor is going to get pretty hot which leads to premature failure.
The best way to do this would be to use a series of 3LED's then a resistor at the end of the series. This helps minimize parts count, keep the power dissipated by the resistor down, and still provide a good balance of brightness. You can then add as many extra sets of 3 LED's in series plus a resistor as you need/want.
If you want bright LED's, like the kind used OEM in car taillights and such, check out "superflux" LED's. They run at 70mA. I have them stock in my G35, and I have also used them in a turn signal project for my G35. To see which LED's I'm talking about, google LTL911SEKSA, LTL911SYKSA. They are made by lite-on. You can buy them from digikey. Lumileds (made by philips) also make superflux LED's, but I do not know their model numbers off the top of my head.
Old May 27, 2008 | 12:44 PM
Aken's Avatar
July 2008 ROTM
Superflux LEDs are way too big for the passenger peg application.
Old May 27, 2008 | 12:52 PM
ORIGINAL: Aken
That could be. I never actually tried fitting one on there. They are generally 7.62mm x 7.62mm cases. To me it just seems like 3mm LED's won't be really bright enough to do much, especially in the daytime. Just my opinion though.
Old May 27, 2008 | 01:02 PM
Aken's Avatar
July 2008 ROTM
Mine look great in the daytime. I left them at full brightness, didn't dim them down for running lights, though.
Footnfool
Mar 17, 2011 10:51 AM
chrislen32
Feb 6, 2011 10:18 AM
ddaren
Jan 17, 2008 07:13 AM
ddaren
Jan 15, 2008 07:46 AM
dco8415
Jun 28, 2007 09:44 AM
