Is adding extra oil really safe?
Old 03-01-2012, 11:47 AM
joelluing's Avatar
Default Is adding extra oil really safe?
I had been reading some threads in the stunt section and read multiple times that if you do wheelies and things of that nature that you should put in more than the recommended 3.5qts of oil.... wont overfilling it hurt the engine?
Old 03-01-2012, 11:55 AM
Shadow's Avatar
Generally yes it isn't good to overfill an engine.
However if you're doing lots of wheelies then you need to know where your oil pump is - if it's at the rear, then filling with extra oil is pointless.
If it's at the front then, having no oil going through the oil pump will wreck your engine very quickly.
If you're doing "stoppies" then the opposite effect will occur.
thrasher572
07-11-2011 01:05 AM
Panda2k1F4i
07-09-2010 10:39 PM
raj1976
06-01-2009 06:46 PM
transamlt1man
05-24-2007 01:54 AM
Muhaha
08-29-2006 03:04 PM
Quick Reply: Is adding extra oil really safe?
