Acumen DGV
Old 01-03-2010 | 11:15 PM
mbison83's Avatar
Originally Posted by letsride
is this what you did?
Theres a little pin you use to push a button in on the back of the display, you push and hold that in until it starts blinking. Then push it in 6 times to tell it you have 6 gears. (Do that with the key on and the engine off) Now start the bike. If you don't have a stand make sure you have an empty road to ride on so you can pay attention to the display; you'll need to use all 6 gears to program it.
Put it in first gear and you can either let it idle or slowly give it some gas. I think you want to change your rev's but the directions say its ok to let it idle. All you're doing here is teaching the indicator your gear ratios. After a few seconds a 2 will start blinking. Shift into neutral, let the clutch out and then shift into 2nd. Slowly give it some gas until a 3 blinks. Then shift into 3rd gear etc. until you get into 6th.
wow. are you serious? i did not do the 1st part, so I guess that's why it was acting all weird. all I did was put it in the learn mode and click it after I get in each gear.
Old 01-03-2010 | 11:33 PM
letsride's Avatar
Hope all goes well then.
Old 01-05-2010 | 11:35 PM
mbison83's Avatar
Man... I owe you some beer So I've programmed it on a rear stand, but what I came across is that after programming gear #1 was not recognized.. it simply showed up as gear #2. The rest of the gears work with no problems.
Here is a pic I took of the 1st gear, if it helps in any way.. I've tried programming it twice but with the same results. I did exactly as you've told me though. Would you know what the matter would be?
Old 01-08-2010 | 10:49 AM
letsride's Avatar
Did you pause in neutral when you shifted from 1st to 2nd?
Old 01-08-2010 | 12:51 PM
mbison83's Avatar
Yes, I did. How long is the pause supposed to be? I waited for few seconds and shifter up to 2nd. BTW the neutral is recognized no problem.
Old 01-08-2010 | 02:49 PM
Timmy_Jones's Avatar
Wow! that is bright.
Silly question, but you letting the clutch out in neutral? Not sure if that would help.
Old 01-08-2010 | 04:24 PM
mbison83's Avatar
Yes. Should I not do that (keep the clutch in, stay in neutral for few secs and go up to the 2nd)? Today I was riding and the DGV was going nuts at times showing me that I was in 6th gear when I pressed the clutch to switch into the 2nd. Pretty weird.
Old 01-08-2010 | 09:50 PM
letsride's Avatar
I dont remember how I did mine,but try it and see if that helps.
lkngood
01-25-2009 04:07 PM
bladerep
06-03-2008 11:54 AM
browningbuck
12-01-2007 07:21 PM
browningbuck
11-28-2007 06:00 PM
