2002 honda cbr 600 f4i fuel injector problem
Alright so i was having my bike turn off on my at stop lights and as the it got worse on the freeway as well. After reading i thought it was my fuel pressure regulator. I replaced it along with my spark plugs, and oil. I started my bike after all of this and it struggled to idle and the fuel injector light kept coming on. Is there anything else it could be other than the actual fuel injectors being clogged?
Also what steps should i take next?
I never asked if you had changed the plugs, I asked what colour they were ,I was trying to find out how rich the engine was running, and of course your right a fuel injected engine doesn't need air to run
The FI light does not mean that there is a fuel injector problem. It means that there is an issue in one of the computer controlled circuits. Have you checked for a stored code yet? That would be the first thing to do when the FI light stays on past the start up check.
You should listen to him, he's one of the more intelligent people on this forum.
If you already had the Rich running condition, I would check out the MAP,TP and IAT sensors, make sure all connectors are tight , and start with the IAT ,take it out give it a clean re-install and see if that makes a difference, you will need a multimeter for all 3, codes are in the workshop manual Section 5
