2002 honda cbr 600 f4i fuel injector problem
Alright so i was having my bike turn off on my at stop lights and as the it got worse on the freeway as well. After reading i thought it was my fuel pressure regulator. I replaced it along with my spark plugs, and oil. I started my bike after all of this and it struggled to idle and the fuel injector light kept coming on. Is there anything else it could be other than the actual fuel injectors being clogged?
Also what steps should i take next? |
Have you checked the Air Filter, how is the bike doing on fuel economy, and how do the spark plugs look (black ?)
If you read the post ive already replaced the spark plugs. I dont see how it could be the air filter when it is a fuel injector problem
Originally Posted by Devin Johnson
(Post 1309034)
The FI light does not mean that there is a fuel injector problem. It means that there is an issue in one of the computer controlled circuits. Have you checked for a stored code yet? That would be the first thing to do when the FI light stays on past the start up check.
(Post 1309034)
Apologies it does run rich at least before i did any of the work. The fi light is intermittent as it idles and is rode
Also im not super expierneced with working bikes do they have a specific code reader to buy for it
If you already had the Rich running condition, I would check out the MAP,TP and IAT sensors, make sure all connectors are tight , and start with the IAT ,take it out give it a clean re-install and see if that makes a difference, you will need a multimeter for all 3, codes are in the workshop manual Section 5
(Post 1309020)
