2 questions in on...talking bout saving space
Old 07-07-2006, 01:20 AM
Glocker23's Avatar
Default 2 questions in on...talking bout saving space
While riding i noticed a ticking kind of sound in the front of the bike and a whining type in the rear. Mind you have been riding this bike since sunday only, but are these sounds normal?
Also a side note, is the rear tire supposed to be flat contoured and then curve around to the sidewalls or is it supposed to be basically round from sidewall to side wall?
Old 07-07-2006, 01:41 AM
Default RE: 2 questions in on...talking bout saving space
not sure on the sound. if you have a lot of miles it could be cam chain tensioner. and same with the tire. milage makes a difference but it depends on the type of tire if its new
Old 07-07-2006, 01:51 AM
Fox's Avatar
Fox
Fox is offline
Sound: Possible CCTL (front). Sounds like a loose/tight chain (rear).
Tires: Normal.
Old 07-07-2006, 06:57 AM
are those easy to fix or do u need a dealer to do that for you? i have ticking sound as well.
Old 07-07-2006, 09:37 AM
from what i've been reading the CCT isn't a big deal as long as u have lower milage. You can hear mine when i get around 6k rpm but it goes away before and after. I heard you don't have to change it until ur up around 8-11k miles or somethin like that....unless of course the sound is getting rediculous. The chain is incredibly easy to tighten/loosen as long as u have a huge socket wrench around....check the links to the user manuals on these forums if u can't figure it out.
Old 07-07-2006, 01:17 PM
Fox's Avatar
Fox
Fox is offline
If you're under warranty, report it to your dealer (for the CCT).
The chain is easy. Helps if you have a rear stand, like Handy, Pit Bull, etc. Instructions are in the MOM.
fatboyslim86
04-17-2011 10:31 AM
live4liftin
F2 Tech
03-15-2010 10:18 PM
92seca2
01-12-2009 03:54 PM
sixshooter989
09-15-2007 12:48 PM
Quick Reply: 2 questions in on...talking bout saving space
