02 f4i fi light. Need help please. Code#13?
Old 11-25-2007 | 05:20 PM
socalcbr1000rr's Avatar
Default 02 f4i fi light. Need help please. Code#13?
fi light flashes once long and 3 times short. I believe that equals=13. Does anyone know what that means?? Thanks
Old 11-25-2007 | 06:51 PM
travsstuff's Avatar
Default RE: 02 f4i fi light. Need help please. Code#13?
#2 injectior connection or faulty injector, however i would double check the battery connections before you tear the bike apart
A long blink = 10
A short blink = 1
CODES:
0 - bank angle sensor, ECM, PGM-FI fuse
1 - MAP sensor
2 - MAP sensor vacuum hoses, or sensor itself
7 - ECT sensor poorly connected or open circuit
8 - TP sensor, TP senspr wiring
9 - IAT sensor connection, or open wire
10 - Baro sensor, or connection, or wiring
11 - Vehicle speed sensor, or connection or wiring
12 - #1 injector connection, or faulty injector
13 - #2 injectior connection or faulty injector
14 - #1 connection or open/shorted circuit
15 - #2 connection or open/shorted circuit
18 - Cam pulse sensor, connection or loose sensor
19 - Ignition pulse sensor, connection or loose sensor
20 - faulty E-PROM in ECM.
thanks to RIGOR over at the FB forums
Old 11-25-2007 | 07:10 PM
Thanks. I'll check it now and post when I get back
Old 10-03-2019 | 06:48 PM
Muiko's Avatar
New Member
Default Code 23
Just got a 2002 and had to replace radiator. It flashing two long and 3 short on codes. Any ideas, thoughts?
Satyajit Sharma
07-06-2019 11:48 PM
Michaud85
11-08-2010 10:55 PM
Tone
06-22-2010 01:50 AM
speed2sound
10-28-2009 06:05 PM
87FC3S
05-09-2008 10:20 PM
