F3 Wanted If you need parts to keep your beast going post it up here. Remember: know who you are dealing with before sending money.
Need a Speedo Cable!
Old 01-17-2011, 02:14 PM
jbrandona`'s Avatar
Default Need a Speedo Cable!
Hey guys! I need a speedometer cable for my bike. The dude didn't finish installing the aftermarket dash, so now I have to lol and I don't want to have to take it to the nearest dealership to order one (if anyone even has them!)
Old 01-17-2011, 11:59 PM
kerosene's Avatar
nooo wait! Doesn't work that way buddy... we don't have a speedo cable, it's a electronic sensor, the gauge needs to be wired up to it... even if you got a speedo cable, you can't mount it up.
If I remember correctly, the speedometer connection on the unit is a - connection, the bike has a +... that's why they didn't wire it up. You can buy a magnetic set from the company, but that'll be ugly... let me do some research and find an answer for you... we may be able to get the - and make it +/- then ground it and connect... that's what I had to do with my Vmax's fuel pump sensor.
Edit...
I checked, the way you'll need to do it is with magnets... You can't wire it up directly like stock is. If you're balsy and are up for it we can try somenthing, but I can't promise it'll work.
Other option is just buy a magnetic speed sensor for the koso unit
http://www.digital-speedos.co.uk/spa...sories-8-c.asp
I believe you have the black plug style.
Old 01-18-2011, 06:32 PM
jbrandona`'s Avatar
Thanks a lot dude. I really appreciate it! is it a difficult installation (the koso sensor), and is that all I will need?
Old 01-18-2011, 08:25 PM
kerosene's Avatar
The sensor is plug and play into the unit (3 pronged) really simple... as simple as plug and play :P
The sensor link I gave you comes with mounting for the magnets and sensor... I believe you unscrew the nuts that hold the brake rotor and screw on the magnet in there... really simple... if you take some pictures of the bike (wiring and wheel, I'll walk you through it.)
Old 01-31-2011, 06:04 PM
jbrandona`'s Avatar
The replacement sensor did not come with the magnets So I'll have to buy them separately. Do you know what size I need? I can't find it anywhere
schmittyf2
F2 Tech
06-27-2010 12:52 AM
exz5string
06-18-2007 03:24 PM
exz5string
06-18-2007 03:16 PM
exz5string
06-04-2007 02:08 PM
bdahl77
04-06-2007 07:14 PM
Quick Reply: Need a Speedo Cable!
