Starter Solenoid shorted, Help ?
Old Apr 19, 2013 | 05:28 PM
91-CBR600-F2's Avatar
Default Starter Solenoid shorted, Help ?
First off i have a 1991 CBR600 F2
Trying to diagnosis the no start issue and found the starter solenoid loose and looks like it ground/shorted itself on the frame.
Besides the solenoid itself what else may have been affected from this. Ecm,Regulator Rectifier, Stator or anything else in that electrical path?
Any insite would be appreciated.
I do have a factory service manual but the wiring diagram page leaves a lot to be desired as its so small its really hard to read.
Thanks in advance
Old Apr 29, 2013 | 03:23 AM
gpfan1's Avatar
Voltage shorted through the solenoid to ground. It gets its signal from a relay that lets big current go to the starter motor. Solenoid maybe fused open, starter maybe affected, starter switchgear on handlebar maybe. Other than that, I don't think other items should've been affected. Hard to tell with electronics. Check out these areas first and fix anything showing signs of burning, melting, etc.
seandcontracting
Nov 3, 2014 01:45 PM
Darrylthenewf
Aug 6, 2008 12:56 AM
ken12
Dec 17, 2007 05:18 PM
929 FRB18
Sep 20, 2006 08:14 AM
