Starter relay
Old Apr 30, 2012 | 09:49 AM
titus sublett's Avatar
Default Starter relay
Which relay will fit f2
Old May 14, 2012 | 02:40 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Someone else might chime in with some specific examples of others that might work, but I'm curious as to why you don't just use a relay intended for the F2 - maybe you're having trouble locating the OEM part?
Anyway, what I would recommend, in the event someone doesn't give you an answer, is to check a parts fiche for different years/models, and just cross-reference the part numbers, to see if any of them call for the same part - this page will allow you to pick different years, and then models, so that you can make the comparison.
Ronayers.com Microfiche Honda>Motorcycle
I hope that helps.
trash2treasure
Aug 7, 2011 02:32 PM
EL Thorsby
Jun 1, 2011 03:04 PM
lonewolfcbr
Jul 18, 2010 04:30 PM
rrrobert
Jul 10, 2008 07:56 PM
