Starter relay
Someone else might chime in with some specific examples of others that might work, but I'm curious as to why you don't just use a relay intended for the F2 - maybe you're having trouble locating the OEM part?
Anyway, what I would recommend, in the event someone doesn't give you an answer, is to check a parts fiche for different years/models, and just cross-reference the part numbers, to see if any of them call for the same part - this page will allow you to pick different years, and then models, so that you can make the comparison.
Ronayers.com Microfiche Honda>Motorcycle
I hope that helps.
I hope that helps.
