starter bad or just jammed?
Old Apr 9, 2012 | 06:07 AM
coldflood's Avatar
Default starter bad or just jammed?
just installed my new battery, poured the acid in and charged it for 5 hours 2amp trickle. starter just clicks. odd thing is that it drops 6 volts between +battery and +starter connection which is oddly enough what the battery drops down to when i engage the momentary(starter) switch. Again same as the last battery. I'm going to take this battery to advanced auto today and have them test it, its been on my float charger all night. Two discharged batteries in a row?
Old Apr 9, 2012 | 06:19 PM
JankCibberf2's Avatar
You sir have a short in your wiring system,
Old Apr 9, 2012 | 06:45 PM
coldflood's Avatar
what makes you say that?
Old Apr 9, 2012 | 07:37 PM
because i sir, had the same issue 2 days ago haha. I kept fully draining charged battery with the click of teh starter. Turned out to be a headlight wire due to the speedometer..
Old Apr 9, 2012 | 10:13 PM
coldflood's Avatar
any chance you could help me out a little more a elaborate so I'll know what to do?
Old Apr 10, 2012 | 07:48 AM
well considering my bike is currently a stunt bike and missing a lot of wires and other randoms, my headlight ground was the issue. Your bike is most likely stock so your going to have to make sure all your grounds are set and not freyed
iPedro
Apr 1, 2014 03:05 AM
nvanvlymen
Aug 2, 2011 02:19 PM
01slvrf4i
May 30, 2007 01:46 PM
ryandrosa
Apr 13, 2007 03:24 AM
