Some error on my front light
Old Apr 12, 2013 | 03:00 PM
Venca246's Avatar
New Member
Wink Some error on my front light
Hello,
I bought last weekend new Honda CBR 600 F2. It is a model from year 1992, US version with 77 kW. Today, I drove on road, when I found out, my central front light is off. I stopped and check the bulb and fuses, but everything was OK. On socket is voltage little or none. On the high beam switch on the handlebars it is similar. Please, have U got some idea? Thanks, Venca
Old Apr 13, 2013 | 09:50 PM
gpfan1's Avatar
Check the connector to the headlight for signs of overheating or melting. How much is "little or none" voltage? Should be 12 volts.
Old Apr 13, 2013 | 11:01 PM
CorruptFile's Avatar
June 2013 ROTM
Check the connector if it's burnt out. If its ok, it might be the headlight cutoff switch in the right hand controls. Spray some PB Blaster in there and that might fix it. The starter switch is designed to cut off power to the headlight during cranking to provide the starter with maximum amperage.
Old Apr 15, 2013 | 04:30 PM
Venca246's Avatar
New Member
Problem solved, switch starter was faulty, the lights are turned on after starting ...contact was singed. But thanks for your advices..
tvn954
Aug 28, 2008 02:09 PM
chpanther69
Apr 21, 2007 06:57 PM
whiteknight
Apr 4, 2007 03:16 AM
mopar
Sep 25, 2005 03:50 PM
