Some error on my front light
Hello,
I bought last weekend new Honda CBR 600 F2. It is a model from year 1992, US version with 77 kW. Today, I drove on road, when I found out, my central front light is off. I stopped and check the bulb and fuses, but everything was OK. On socket is voltage little or none. On the high beam switch on the handlebars it is similar. Please, have U got some idea? Thanks, Venca
Check the connector if it's burnt out. If its ok, it might be the headlight cutoff switch in the right hand controls. Spray some PB Blaster in there and that might fix it. The starter switch is designed to cut off power to the headlight during cranking to provide the starter with maximum amperage.
