REVS taking there Time
Old Apr 30, 2010 | 10:01 PM
C Average's Avatar
Default REVS taking there Time
okay so I posted this is general tech, but whos some people only ready the f2 threads. My bike takes it time to let the revs down. My carbs are out of sync. Does this cause that
Old Apr 30, 2010 | 10:11 PM
C Average's Avatar
note that i moved the needle up to try and correct this and its still acting the same
Old Apr 30, 2010 | 10:12 PM
dustinjklee's Avatar
that could cause it also another thing that could cause that is you idle/air mixture could be to lean. try adjusting them out a half a turn see if that helps. also intake leaks and exhaust leaks will cause this to
Old Apr 30, 2010 | 10:18 PM
C Average's Avatar
well I did that, I went from 2 out, to 2 3/4 out with the neeedle at the 2nd from top, then moved it to the middle clip, and tried 2 out and then 2 3/4 then the same
So for sure if its way out of sync it will do this ? Im pretty sure theres no intake leak cuz I tighted the boots and box really well
Old Apr 30, 2010 | 10:55 PM
i dont know if the out of sync would do it ive never ran my bike with it way out of sync ive always synched mine after tinkering with the carbs
Old May 1, 2010 | 08:05 PM
RoosterF3's Avatar
have you messed with the idle set screw to see if thatll fix it?
Old May 3, 2010 | 11:23 AM
cbr900racer77's Avatar
Out of sync wouldn't do it. Best way to tell if yours are out of sync, it'll have a stumble immediately after you hit the throttle. After you get r's up, out of sync plays no part in how your bike runs. Only thing it causes is that stumble due to 1 or more butterflies being slightly behind the others.
Old May 4, 2010 | 08:50 PM
C Average's Avatar
Yeah I synced her up and its all good now. Finally Now I can work on the cosmetics now rather that she runs nice
dalves11
Sep 22, 2010 04:47 PM
19meza85
May 31, 2010 11:52 AM
C Average
Apr 30, 2010 11:08 PM
Drekk
Jan 11, 2010 01:09 PM
TxRida
Aug 14, 2008 04:14 PM
