Rear brake pad pin
Old May 16, 2012 | 11:05 AM
qedmoto's Avatar
Default Rear brake pad pin
Hey all,
I'm having some trouble replacing my rear brake pads. I unscrewed the stopper but can't loosen the pin that the pads attach to. It won't come loose. Any suggestions would be appreciated.
Thanks!
Old May 16, 2012 | 11:27 AM
coalminer frank's Avatar
Did you leave the caliper mounted on the bike? It should make it easier to brake things loose. Once there loose, then remove caliper and fininsh taking out the pins. I put antiseize on mine when reinstalling them to make the next time easier. But not the stop plugs that go on top of the pins. Get a torque wrench and bike manual and torque all your bolts to spec. You know how guys are, we like to tighten stuff way to much.
Old May 17, 2012 | 01:38 PM
qedmoto's Avatar
It was off the bike because I had to change the rear tire and sprocket. I'm going to put it back on and remove it the way you suggested. Ive got the manual so I'll be sure to torque them down to spec. Thanks a lot!
Old May 17, 2012 | 06:14 PM
MadHattr059's Avatar
Might try to soak it with a break-free, lubricant and then let it soak for a bit before
your next try.
If it keeps being stubborn, you can try a little heat (preferably, from an electric hot-air
blower).
If you have an impact-driver, that can help too. Got to watch out, that you don't strip
the allen-head, though. I did that once, had to use a pair of vice-grips on the center
of the hanger-pin. Then I had to chuck it in the drill-press and turn out the gouges
with a file. Don't pull an Ern, if at all possible, lol.
Good luck, Ern
zellster
Aug 19, 2019 06:44 PM
gambit07
Mar 30, 2011 02:25 PM
Hayden06F4i
Jun 17, 2008 09:50 AM
JJHUNSECKER
Sep 16, 2006 03:22 AM
mini bagels
Sep 4, 2006 04:31 PM
