problems
Old Feb 1, 2012 | 03:28 PM
cbrfresh94's Avatar
Default problems
Hit a quick question... When I turn my bike on with choke it runs fine, but when I turn the choke off the bike cuts off, someone said the carburetor needs to be cleaned, someone else said the idle needs to be adjusted? Any advice would be greatly appreciated...thanks
Old Feb 1, 2012 | 05:53 PM
5p00f3r's Avatar
I had the same problem and I did both, cleaned the carbs and adjusted the idle a bit..now its fine...
Old Feb 1, 2012 | 06:36 PM
MadHattr059's Avatar
Yuppers to above. Before you pull the carbs, try running a can of Sea-foam thru a
tank of gas. I'm assuming that if you get it warmed up, you are able to ride it.
As 5p00f3r says, after you get it warmed up, try adjusting the idle. If it's like the F3,
there's a **** on the end of a cable. It's below the pet-****, under the left side cover.
If I remember correctly, CW to advance the speed, CCW to lower the speed.
Try those first, see where that gets you. Then check-back if you need some further
tips.
Hope this helps, Ern
Old Feb 1, 2012 | 07:14 PM
cbrfresh94's Avatar
tips.
Would the idle adjuster be on the outside of the cover but the fuel reserve switch?I have a little notch there connected to to a cable...don't know what its for?
Old Feb 1, 2012 | 07:59 PM
Might be, is it supported by a wire loop on off the frame? I've got a slightly different
bike, so I can't say for sure. If it's just atightly looped coil with a **** on the end,
that's probably it. Try turning the **** after the bike's warmed up and see if the
engine speed changes.
Ern
Old Feb 1, 2012 | 08:52 PM
cbrfresh94's Avatar
Ok thanks bro
Old Feb 2, 2012 | 11:29 AM
JankCibberf2's Avatar
clean that air fresher
m21oliver
Oct 1, 2018 10:52 AM
clintthec
Jul 27, 2011 06:04 PM
honda23
Jun 28, 2011 12:24 PM
cr cbr
Nov 28, 2006 04:36 PM
