problems
Yuppers to above. Before you pull the carbs, try running a can of Sea-foam thru a
tank of gas. I'm assuming that if you get it warmed up, you are able to ride it.
As 5p00f3r says, after you get it warmed up, try adjusting the idle. If it's like the F3,
there's a **** on the end of a cable. It's below the pet-****, under the left side cover.
If I remember correctly, CW to advance the speed, CCW to lower the speed.
Try those first, see where that gets you. Then check-back if you need some further
tips.
Hope this helps, Ern
tips.
tips.
tips.
