noob question before buying
Old Jul 16, 2013 | 02:55 PM
Artie Rivera's Avatar
Well, in the case of them being F3 forks, what is the best solution for having a working speedometer?
Old Jul 16, 2013 | 04:12 PM
adrenalnjunky's Avatar
Well - the F2 engine doesn't have the speed sensor the F3 engine does. F4i digital gauge cluster upgrade might be where you start looking. That, or you throw a cheap GPS on.
Or you just figure out how fast you run at certain rpm's in what gear and commit it to memory.
Old Jul 17, 2013 | 02:42 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Junky mentioned the F4i cluster, and I know a lot of guys have gone that route, using a speedo-healer, and sourcing a compatible sprocket cover with a speedo sensor - I'm not sure which bikes they usually get these from, but I know there's something out there that mounts up - maybe someone who has done this will chime in, or, you can just search the forum for "gauge conversion", or something of the like, and you might find some of the prior threads that I've long ago read and forgotten!
Another option is to go with an aftermarket gauge set, which uses magnets and a sensor on the front wheel for speed measurement - you've just got to calibrate the set for the circumference of your wheel, just like on a bicycle speedo unit... Koso is what I would recommend.
Lastly, if you don't want to have to do so much work just to make an incorrect part do the job, like I mentioned before, the seller messed up... send it back and keep searching for a '94 F2 fork set.
DANE-GER
May 18, 2011 11:19 PM
CBRockin
Dec 22, 2010 08:06 PM
Doherty80
Jul 9, 2010 12:09 PM
murdocity
Sep 16, 2009 04:24 PM
Vanandt71
Jul 29, 2009 07:40 PM
