No start, just click, roll starts perfect
Old Jul 27, 2011 | 12:04 PM
young7.3's Avatar
Mine won't go down.only left up and right
Old Jul 27, 2011 | 06:22 PM
adrenalnjunky's Avatar
then something's wrong - or you have an aftermarket petcock on your bike.
Old Jul 28, 2011 | 01:44 AM
PanMan's Avatar
working on the assumption it's a standard petcock that's somehow been fitted 90 deg out of kilter then it ill be
left on
up off
right reserve
if it's an aftermarket item then YMMV
Old Jul 28, 2011 | 10:32 AM
young7.3's Avatar
Your right pan man.left is on,up is off,right is reserve.back to the starting problem,I tried a different battery I know is good that was on the 4 wheeler and still nothing.
Old Jul 29, 2011 | 07:04 PM
young7.3's Avatar
After connecting a jumper cable up to the starter directly it still wont start. I used the same battery to test the original starter that was in it(off the bike) and it turned. What gives?
Old Jul 30, 2011 | 12:12 AM
PanMan's Avatar
is the ground/earth lead connected properly at the starter?
Old Aug 8, 2011 | 01:07 PM
young7.3's Avatar
Ok, so i got the battery tested and its good. I tested the starter solinoid with a voltage reader and the hot side has a constant 12.4 volts with the key off. The starter side has 6.3 volts with key on and starter button pressed in. looks like i need a new solinoid?
Old Aug 8, 2011 | 04:06 PM
coldflood's Avatar
if your feeling ambitious you could always take the starter/solenoid off put jump it with the battery and listen for the solenoid to plunge but i dont know how that would be in different than if it were on the bike
Old Aug 10, 2011 | 11:24 AM
young7.3's Avatar
Does it sound like the solinoid needs replaced? I checked the voltage at the starter and its only getting 5-6 volts.How many volts does it take to turn the starter over?
Old Aug 14, 2011 | 10:19 AM
ttemp56's Avatar
You need a full 12 to kick a starter. Or probably about 10.5 to make the starter flinch. its weird that the old starter works while off the bike and this one won't while on the bike and directly connected to the batt... Im with panman, check your grounding on the bike make sure its not loose or rusted.
