Intermitant starting problem
Old Nov 20, 2011 | 05:09 AM
tomtom's Avatar
Default Intermitant starting problem
Hi all, hope you can help me. Went out to start bike, turned ignition on, light and dials came on as it should, bike in neutral. Went to push start button and nothing happened. It's done this on rare occasions before and I bump start the bike and it starts first time.
As I was pushing the start button this time I don't know why I did it but I pushed the horn button and then the bike started to crank over and started.
Wondering if you'd come across this before? or any ideas why it started after I pushed the horn button!?
Thanks Tomtom
Old Nov 20, 2011 | 09:07 AM
MadHattr059's Avatar
Not sure if the horn thing is connected or coincidence, but test the wiring from the
starter to the battery/ground. If you have a loose ground or other connection, it can
exhibit intermittent failures.
If that checks out then move on and check the starter-relay, then finally, you might
scope out the starter switch, itself.
Ern
dirtyhall
Apr 15, 2011 08:41 AM
CBRPutty
Aug 12, 2010 09:04 PM
dgraviett
Jul 14, 2009 10:59 AM
whtan20
Nov 25, 2007 01:36 AM
ITZOBIG
Apr 14, 2007 11:56 AM
