How to get at spark plugs?!?!
Old Apr 17, 2010 | 09:56 PM
koelzer001's Avatar
Default How to get at spark plugs?!?!
If anyone read up on me in my intro i just bought an f2...I am pretty mechanically inclined, I rebuilt the car thats in my pictures on here...I cannot, CANNOT get at those damn spark plugs...Can anyone please tell me what the easiest way is? The closest I got is when the tank is off bending back the rubber in front of what I believe would be the coils, and I could only get at like one from there...My bike is down until I get this figured out, Ive read the manual and cant find anything in there about it. Someone please help me!!!
Old Apr 17, 2010 | 10:13 PM
jnicola's Avatar
You've rebuilt a car all the way and never used a universal joint to get at funky angles? You gotta get some and try them, they make such jobs a breeze!
Anyways, you can also remove the airbox all the way for some additional accessibility, but again, a UV joint is highly desirable.
Old Apr 17, 2010 | 10:23 PM
koelzer001's Avatar
Im not dumb enough to have not tried that...Thats not the point though, I cant possibly get to the other three spark plugs with just pulling that rubber down, and I did have the airbox completely removed
Old Apr 18, 2010 | 12:15 AM
Sand.Man's Avatar
Attack it from the side, not the top.
Drop your deep socket down the hole, then drop the extension, then snap your wrench onto the extension all one piece at a time.
Old Apr 18, 2010 | 01:50 AM
koelzer001's Avatar
to the sandman, what do I really have to take off? or do I still have to take off the tank, airbox, etc...
Old Apr 18, 2010 | 03:32 AM
TallBoss's Avatar
yes you do. put your spark plug socket down there first then a 1 inch extention then the swivel then a 12 inch extention the the ratchet. i just did mine in 10 min. not that hard.
Old Apr 18, 2010 | 09:10 AM
koelzer001's Avatar
Ok, one more questions, so you guys loosened your coils and pulled that rubber piece back? or did you go from the side like sandman said? If so do I have to take off the fairings on both sides?
Old Apr 18, 2010 | 12:13 PM
nitrodude's Avatar
The easiest way, for me anyways, is take off both of your side fairings get the correct size spark plug socket, and an extension.
Put the extension on the correct size spark plug socket and then take that and from the side turn it sideways and then put it down into the spark plug hole. Then put your socket wrench on the end of the extension. You cant get the socket in there with it on the wrench.
You should be able to remove spark plugs on cyl 1 and 2 from the left side and spark plugs on cyl 3 and 4 on the right.
Old Apr 18, 2010 | 12:37 PM
koelzer001's Avatar
I got it, but it was ab****, thanks guys
baseballkid
Oct 4, 2012 07:48 AM
jvhjgh2006
Jun 26, 2011 02:07 AM
Carbon_cavvy
Feb 29, 2008 08:25 PM
eukanuba517
Feb 19, 2008 04:54 PM
mikey1297
Jul 11, 2006 02:42 PM
