front end dives when i brake
Old Apr 7, 2010 | 11:55 PM
moneyschott's Avatar
Default front end dives when i brake
hey all, when i brake on my 93 f2 the front end dives really bad. there are about 13k miles on it, are the shocks just worn out? are they adjustable? as in can i just tighten them up?
Old Apr 8, 2010 | 12:25 AM
nmario's Avatar
does your bike have the anti dive system on it ?
Old Apr 9, 2010 | 04:02 PM
johnnyx's Avatar
13,000 isn't bad, but if its been ridden hard, you should be looking at your fork seals. Change your seals and fork oil, and see where you end up; I bet you've just blown them and have junk compression in there now.
Old Apr 13, 2010 | 12:41 PM
g32bturbo's Avatar
how much do u weigh?
Old Apr 13, 2010 | 01:54 PM
johnnyx's Avatar
Woah, yeah, duh: Did you set your suspension up for your weight when you got the bike????
Old Apr 15, 2010 | 10:29 AM
I weigh 145, I don't think that should be too much for th bike! Can I adjust it to be firmer?
Old Apr 15, 2010 | 11:44 AM
johnnyx's Avatar
You sure can, but they come from the factory set for 165, so unless the PO really lightened them up, you probably have a mechanical issue.
Old Apr 15, 2010 | 02:49 PM
jnicola's Avatar
See those flat head screws on the top of each fork, where your handlebars clip on? Yeah, that's where you adjust the pre-load. Turning it to the right cranks down on the spring, causing it to be stiffer. This however does reduce travel somewhat. Turning it to the left backs it out, making the spring softer as it's less compressed, and giving it more travel.
Personally, I would do the following as your weight is fine for those springs:
-Empty fork oil
-Redo seals
-Adjust for proper sag.
Do all of that, and you'll be good to go!
edge1
Jul 10, 2010 03:59 AM
6doubleohf3
Oct 25, 2009 09:01 AM
GetOuttaMyWay
Aug 6, 2009 03:13 PM
FLYOU
Jul 13, 2007 08:12 PM
JJHUNSECKER
Sep 16, 2006 03:22 AM
