fan fuze
Old Jul 14, 2010 | 08:16 PM
C Average's Avatar
Default fan fuze
My bike has eatin 4 fuzes for the fan TODAY. It just sarted doing this. Any ideas what could be going on
Old Jul 14, 2010 | 09:06 PM
nitrodude's Avatar
Right size fuse? Fan caught and not able to spin freely?
Those would be my 2 queses, make sure that you can spin the fan freely and its not stuck on anything and make sure you are using the right size fuse.
Old Jul 14, 2010 | 10:30 PM
C Average's Avatar
yeah. its the right size . a 10 I even tried a 15..and it spins
Old Jul 14, 2010 | 10:36 PM
nitrodude's Avatar
Next thing to do is check wires...make sure no wires are crimped or shorted on the frame/together or whatever. Check make sure your plug to the fans not melted.
Old Jul 14, 2010 | 11:13 PM
C Average's Avatar
i can splice wires and all that good stuff.but dont know half as much as i want to about electrical. but what wire should I buy to replace it. just 12v wire from radio shack
Old Jul 14, 2010 | 11:42 PM
nitrodude's Avatar
Just go through and make sure none of the wires have any nicks on the outer cover exposing the metal wire inside. Make sure no wires are crushed or anything. Makes sure none are melted, etc.
If any are bad, you can most likely get away with cutting, splicing, soldering, and heat shrinking them back together if its a small section.
Old Jul 15, 2010 | 12:09 AM
C Average's Avatar
would I really even have to solder them. I mean I have a iron. but couldnt I just snip out the bad and reconnect with some connectors
Old Jul 15, 2010 | 12:20 AM
nitrodude's Avatar
You could, Is it as reliable? No. Its better to solder, and shrink em. Do it right the first time so you dont have to do it again.
devildogsc
Aug 29, 2008 12:03 PM
