F3 Fuel Petcock Vavle On F2 Bike
I don't think it's a straight-up bolt-on. If I'm correct the F2 uses a vacume shut-off.
The F3 has a fuel-pump and doesn't use one. It would be easy to run the vac line off the carbs, but there might be issues with fuel flow.
I would either, do the re-build (as suggested) or stick with the F2 petcock for
replacement.
Ern
replacement.
Ern
Well yes and no. It will bolt on and it will work because vacuum is only for shut off, but you will need to plug the vacuum port on the carb. Does that count as a modification?
edit: Btw Im not trying to convince anyone to use an f3 petcock, I run the f2 one, but just answering the question.
I run and F3 petcock in an F2. Plug the vaccum line and you will be fine. If your needle valves dont leak you can leave it on the on position all the time. I usually do. Turn it off if you are paranoid about it. And if you are going to leave it on just be observant of gas smell before you start
cbrboyze
How-To: Mechanical
03-05-2009 08:47 AM
