F3 clutch in an F2?
Old Dec 17, 2010 | 06:57 PM
jcon82's Avatar
Default F3 clutch in an F2?
awhile ago i got a clutch set (frictions,steels,springs and gasket) dirt cheap off ebay and when it came in the mail the label said f2/f3. so my question is , will it work in my f2? also i read that a special tool is needed for instalation, can it be done without this tool since my local honda shop seems hesitant to rent it to me. thanks in advance for any help
Old Dec 19, 2010 | 10:18 AM
jcon82's Avatar
any ideas? if i cant figure it out i guess i'll just sellit on ebay
Old Dec 19, 2010 | 11:24 AM
jcon82's Avatar
ok so i did some research and found that although KG clutch (my kit) lists f2 and f3 friction sets as different part #, most other manufacturers list that the same set will work on f2, f3 , 900rr and vfr, what gives? the steels and springs will work for both models too.
Old Dec 19, 2010 | 12:04 PM
Sand.Man's Avatar
It should work, I'm pretty sure the clutches are identical.
Old Dec 19, 2010 | 08:47 PM
jcon82's Avatar
cool, now what about this special tool the dealer said i need? can i do the job without it?
Old Dec 19, 2010 | 09:12 PM
Sand.Man's Avatar
You'll need an impact gun, drain the oil first
Old Dec 20, 2010 | 06:27 AM
jcon82's Avatar
thats it? is there a thread on this? tried to search but no luck.
Old Dec 20, 2010 | 06:31 PM
Sand.Man's Avatar
All the info is in the shop manual, step by step... But I do think there is a step by step on the forum too.
Old Dec 20, 2010 | 06:39 PM
Sand.Man's Avatar
I did a write-up a few years ago but I can't find it... All of my posts before 2009 are gone
Zandaloo
Aug 22, 2013 03:26 PM
Bordo
Sep 21, 2012 07:33 PM
02f4irider
Mar 6, 2009 07:50 PM
red stinger
Jul 19, 2008 12:17 AM
cyber00677
Jun 23, 2007 06:17 PM
