F2 - F4i Gauge swap write up
After much research, trial and error, and the search button i got it working
What you need
1. F4i gauges
2. 95-98 900rr front sprocket cover with speed sensor
3. Crimper
4. about 5 feet of wires
5. Quick connect female/ Male connectors (i like quick connects)
6. Alot of time.
edit_----
7. Speedohealer V4
First cut the ends off your f4i gauge and expose all of the wires and crimp the quick connect to the wires. Its smart to use all males on one end so you don't mess anything up later when connecting the wires.
Strip the wires from the F2 that go to the original speedometer and crimp the quick connect plugs on it.
Here is the wiring diagram that you will need to use for these wires.
F2 colors ==== F4i colors
Tachometer
Yellow / green ==== Yellow/Green
Temp
Black/ Brown ==== Green Blue
Left turn
Orange ==== Orange
High Beams
Blue ==== Blue
Neutral
Light Green / Red ==== Light Green / Red
Oil Pressure
Blue / Red ==== Blue / Red
Side Stand
Yellow/ Black ==== Green / White
Right Turn
Light Blue ==== Light blue
Dont know what this wire does but it needs to be connected.
Black/Brown ==== Black/Brown
Speedometer 900rr Sensor
black wires goes to black/brown,
pink wires to pink/green
green goes to to green/black.
Red/Green goes to battery
Wires that you dont use (from tach)
Brown/Black - fuel reserve sensor -*not used *****************************************
White/Blue - fi indicator - not used.
Also you need to wire in a speedohealer so the speedometer can read the correct speed otherwise it will just read up to about 20mph when your really going about 80-90mph
Im going upload some pictures and a video of it working
What you need
1. F4i gauges
3. Crimper
6. Alot of time.
edit_----
7. Speedohealer V4
Tachometer
Temp
Left turn
Orange ==== Orange
High Beams
Blue ==== Blue
Neutral
Oil Pressure
Side Stand
Right Turn
Only one question, does it look stupid? I mean, does it line up nice with the rest of that area or did you need to mod something. Also, does it bolt right up and can you use the same stay?
Other than that, I would like to do this to my bike. I am almost done painting it and just put an integrated tail light on so this would go nice with my newly finished old bike. lol
uploading the pic's right now, trying to get the video working. Also, on a side note my speedometer stopped working (well it only goes to 18 since i believe i have shorted out the sensor) never the less it still works. I have ordered a new sensor and waiting for it to come
just uploaded a video of this working here is the link
http://www.youtube.com/watch?v=VHlP1-FW4Lg
----edit you need a speedohealer to get the correct speed to show....... here is some more information on this http://www.rrzone.com/forums/showthr...?t=3545&page=6
